Deo3000
Apr 13, 2018Aspirant
iPhone ReadyCloud can not connect internarnally to ReadyNas 104 OS 6.9.3
ReadyCloud in the iPhone does not connect internally (when I am in the same network). ReadyCloud in the iPhone can connect when in the Celular network or in another WiFi. ReadyCloud in the Mac can ...
JohnCM_S
Apr 13, 2018NETGEAR Employee Retired
Hi Deo3000,
Welcome to the Community!
1. What is the version of the ReadyCLOUDapp installed on your iPhone?
2. Are you able to access NAS via ReadyCLOUD portal using your iPhone's web browser?
3. If you have another iOS device, are you getting the same issue as well on the ReadyCLOUD app?
Deo3000
Apr 14, 2018Aspirant
Hi John
Version 2.0.1,(2040)
Yes, I can connect with my IPhone web browser using the readycloud.netgear.com and directly <ip>
Yes, I have an iPad
