Deo3000
Apr 13, 2018Aspirant
iPhone ReadyCloud can not connect internarnally to ReadyNas 104 OS 6.9.3
ReadyCloud in the iPhone does not connect internally (when I am in the same network). ReadyCloud in the iPhone can connect when in the Celular network or in another WiFi. ReadyCloud in the Mac can ...
JohnCM_S
Apr 13, 2018NETGEAR Employee Retired
Hi Deo3000,
Welcome to the Community!
1. What is the version of the ReadyCLOUDapp installed on your iPhone?
2. Are you able to access NAS via ReadyCLOUD portal using your iPhone's web browser?
3. If you have another iOS device, are you getting the same issue as well on the ReadyCLOUD app?
Radek71
Apr 14, 2018Aspirant
Hi John,
I have exactly the same problem:
- ReadyCloud connection works fine from web browser - internal (home) network and also internet.
- ReadyCloud connection works fine from Android device - internal (home) network and also internet (wifi or LTE). App version is 1.2.11 (last one).
- ReadyCloud connection works fine from iOS device iPhone and iPad - external network, internet (wifi or LTE). App version is 2.0.1 (last one).
- ReadyCloud connection does not work from iOS device iPhone and iPad - internal (home) network. App version is 2.0.1 (last one). There is information window: Error/Network error occured.
Regards
Radek
- JohnCM_SApr 19, 2018NETGEAR Employee Retired
I did not encounter this issue when I simulate this on our end. May I know the iOS version of your Apple devices?
- AnonymousApr 20, 2018
PM sent
- Radek71Apr 23, 2018Aspirant
iPhone SE v. 11.2.6
iPad v. 9.3.5
I do not think the problem is in the iOS version. The previous version of the ReadyCloud worked without any problem on the same devices with the same version iOS.
Regards
Radek
- Deo3000Apr 23, 2018Aspirant
I emailed you the requested files.
