Deo3000
Apr 13, 2018Aspirant
iPhone ReadyCloud can not connect internarnally to ReadyNas 104 OS 6.9.3
ReadyCloud in the iPhone does not connect internally (when I am in the same network). ReadyCloud in the iPhone can connect when in the Celular network or in another WiFi. ReadyCloud in the Mac can ...
Radek71
Apr 14, 2018Aspirant
Hi John,
I have exactly the same problem:
- ReadyCloud connection works fine from web browser - internal (home) network and also internet.
- ReadyCloud connection works fine from Android device - internal (home) network and also internet (wifi or LTE). App version is 1.2.11 (last one).
- ReadyCloud connection works fine from iOS device iPhone and iPad - external network, internet (wifi or LTE). App version is 2.0.1 (last one).
- ReadyCloud connection does not work from iOS device iPhone and iPad - internal (home) network. App version is 2.0.1 (last one). There is information window: Error/Network error occured.
Regards
Radek
JohnCM_S
Apr 19, 2018NETGEAR Employee Retired
I did not encounter this issue when I simulate this on our end. May I know the iOS version of your Apple devices?
- Retired_MemberApr 20, 2018
PM sent
- Radek71Apr 23, 2018Aspirant
iPhone SE v. 11.2.6
iPad v. 9.3.5
I do not think the problem is in the iOS version. The previous version of the ReadyCloud worked without any problem on the same devices with the same version iOS.
Regards
Radek
