Deo3000
Apr 13, 2018Aspirant
iPhone ReadyCloud can not connect internarnally to ReadyNas 104 OS 6.9.3
ReadyCloud in the iPhone does not connect internally (when I am in the same network). ReadyCloud in the iPhone can connect when in the Celular network or in another WiFi. ReadyCloud in the Mac can ...
JohnCM_S
Apr 19, 2018NETGEAR Employee Retired
I did not encounter this issue when I simulate this on our end. May I know the iOS version of your Apple devices?
Radek71
Apr 23, 2018Aspirant
iPhone SE v. 11.2.6
iPad v. 9.3.5
I do not think the problem is in the iOS version. The previous version of the ReadyCloud worked without any problem on the same devices with the same version iOS.
Regards
Radek
- Deo3000Apr 23, 2018Aspirant
I emailed you the requested files.
iOS version 11.3
- Retired_MemberMay 02, 2018
Hello Deo3000
I've received logs&configuration you sent me,ReadyCLOUD dev is still investgating the issue,I will update this post if they found root cause of the issue.
