Blueray3
Oct 03, 2016Guide
MyNETGEAR account, ReadyCLOUD, and ReadyNAS 312
I'm using a Readynas 312 with mynetgear readycloud account. If I add another Readynas 312...with separate shares, do I use the same readycloud login for each? -Or should I get a new email account an...
- Oct 03, 2016
Also note that if you use local users as well as ReadyCLOUD users the local users must not have the same email address specified as for ReadyCLOUD users.
anna_arun
Oct 03, 2016NETGEAR Expert
You can use the Same Readycloud account with multiple ReadyNAS . Once you login to ReadyCLOUD on Webpage or on PC App , it will show up all your devices list . Click on each to see your folders . Process is very much simplified Post 6.5 Firmware Update .
The ReadyCLOUD account you Join is the administrator , later if you need to give access to a particular share you may invite people with their email id . They could create their own account with their email id & see only the folder you have authorised .
