ooooo's avatar
ooooo
MyNETGEAR erroneously indicating that product is already registered
Hi
- I logged into MyNETGEAR. I got a first message that says "No products registered under your profile".
- I tried to register my brand new RN202 for which I provided the serial number and purchase date.
- I got a message saying "Something went wrong, Please contact support team."
- There is neither an indication of what that "something" is, nor an e-mail, URL, phone or any specific way of contacting the said "support team".
- In the Registration page (https://www.netgear.com/mynetgear/register/register.aspx) I entered the required data and got a message saying "Serial number already registered."
- So, a) I got the "No products registered under your profile" message, b) the product is brand new, and c) when I tried to register the product I got a message "Serial number already registered."
...as you can see up to this point... TERRIBLE USER EXPERIENCE with this product registration thing.
Then in https://www.netgear.com/support/contact.aspx I read... "Register your product to activate complimentary support" which I attempted, only to get the same message as above "Serial number already registered."
Can someone from NETGEAR please get my product registered?
Thanks
  • Hi ooooo
    It might not appear on MyNETGEAR but it seems it's already registered to your profile.
    I would suggest contacting NETGEAR to verify this. I have sent you a PM.
    Regards
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Hi ooooo
    Welcome to the Community!
    Can you PM me the S/N of your RN202 so we can check.
    Regards
  • Marc_V's avatar
    Marc_V
    Hi ooooo
    Regards
    • ooooo's avatar
      ooooo
      Thanks Marc_V.
      Does anyone know what's the best way to contact NETGEAR on this? Yesyerday I called the only number I was able to find on their website, "Premium" Technical Support. After over 100 minutes on the phone, I gave up since none of the three reps I talked to was able to solve the problem.
      Thanks.
ProSupport for Business
