fabsfabs
May 20, 2016Follower
NAS is offline on ReadyCloud, with new migrated account to MyNetgear; and firmware 6.5.0
Hello Netgear Community, doubble trouble.... - NAS RN102 permanently offline on ReadyCloud, - New migrated "MyNetgear" Account, forced product registration, - but, product Serial Number is ref...
- May 24, 2016
Hi JennC,
Yes I understand and I made the migration properly, at least I thought I did. I did everything all over again and then I got connected again. I am not sure that this actually was the problem that solved the case but I am happy for having my NAS-connection up and running again.
Thanks for all help :-)
//matterhorn
JennC
May 20, 2016NETGEAR Employee Retired
Hello fabsfabs,
Make sure your ReadyNAS is getting on the Internet. The Services Offline indicates that it is not getting on the Internet.
The registration of the SN has nothing to do with the ReadyCloud access. You should still be able to use ReadyCloud and your ReadyNAS without even a registered product. When you create or upgrade to a myNetgear account, this is the same account you will use to login to the readycloud.netgear.com, it should be in an email format. The upgraded ReadyCloud account (which is now a myNetgear account) that you enter in the ReadyCloud feature of the admin page > Cloud should be in an email format too. So it you are already using the ReadyCloud before the upgrade, you need to upgrade your ReadyCloud account too,
Welcome to the community!
ANDT
May 20, 2016Initiate
Hello I have the same problem, all seems to be good but it's offline.
Best regards
