cduggins
Jun 24, 2022Guide
NAS shows Online(VPN Disconnected)
My son and I both have ReadyNas and share documents. Today I see his NAS on ReadyCloud but it says says Online(VPN Disconnected) I cannot see any files..... I called him, he says on his end my NAS ...
- Jul 02, 2022
Thanks for all the help.
I turned VPN off and problems went away.
Marc_V
Jun 28, 2022NETGEAR Employee Retired
Have you tried rebooting the NAS as start? Also verify if the NAS is connected to the Internet, You can check as well in the Cloud tab if there are check marks for Services and Internet. If after reboot still you are getting VPN disconnected issue, try to turn off the readycloud service and toggle it back.
HTH
cduggins
Jul 02, 2022Guide
