lochiano
Jan 27, 2018Aspirant
Network card failue after upgrade
I have two ReadyNas drives. I upgrades my 312 based on the prompt without any issues but when I did the same thing to the 214, the network cards failed. The display said, no IP addres. What I have...
lochiano
update:
RAIDar does not discover the NAS
Resetting the cable mobel has no effect
disconecting the network cable has no effect
moving a network cable from a valid machine has no effect
- StephenBJan 27, 2018Guru - Experienced User
Did you try powering down the RN214 and then restarting it?
- lochianoJan 27, 2018Aspirant
yes I tried power and recycle. It had no effect.
- StephenBJan 28, 2018Guru - Experienced User
Try powering down, removing the disks, and then power up.
See if RAIDar detects the NAS with a no-disks status. https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
