DBVD
May 31, 2022Aspirant
Online (VPN Disconnected) on a Mac - NOTE NEVER SOLVED FOR ANYONE IN NEARLY 10 YEARS!
This issue has been happening as early as 2015, based on the oldest Community posting I found. Note this: Many posts are marked SOLVED - They are NOT solved, and these so-called solved statuses s...
DBVD
Jun 01, 2022Aspirant
I cannot find a way to send you my log files and information securely. Is there a way for us to do this?
I tried going to MyNETGEAR where my NAS is registered, but I cannot create a support ticket without paying.
NETGEAR not looking too good on support to their customers of their products.
Marc_V
Jun 02, 2022NETGEAR Employee Retired
Can you use a file sharing app or service and provide me a link to download it?
If you can't create a case on your profile please send an e-mail to readynassupport@netgear.com. This should create a case for you automatically that will go to the ReadyNAS Support team. You can also provide the logs to them via Email.
HTH
- DBVDJun 02, 2022Aspirant
Hello and thank you once again for your timely response. You are giving me hope that this might actually get resolved, and I greatly appreciate your support with this.
I have done as you suggested and sent an email including all information to date. I also attached the log files, so thank you for your excellent recommendations.
Thank you again. I am available and eager to help in any way I can to get this resolved.- Marc_VJun 02, 2022NETGEAR Employee Retired
I am following the case now and will make sure to check. I have removed the case number on your post.
Thank you very much for all. Sounds great and I am very hopeful.
If techs need to remote into the Mac to troubleshoot, that's not a problem.
Thanks again.
