NASty1
Mar 27, 2015Aspirant
OS 6.2.2 and readycloud.
After installing OS 6.2.2 , I found that some "cloud" users couldn't access their accounts. I realize that the problem is probably with the netgear "cloud" servers, but I don't know how to straighten...
Nhellie
Mar 27, 2015Virtuoso
Try logging in to readycloud.netgear.com using the account that you are having issues with. Remove the username and then re-create it from there. Once done, check if you may allow access/ permission to that newly created user to a specific share.
