RyeBread
Apr 22, 2016Tutor
ReadyCLOUD App not working but works fine on the web
Hello, The readycloud app on my win10 just says connecting but it never will, and the "readycloud.netgear.com" works just fine...
- Apr 28, 2016
Hi RyeBread,
We appreciate your feedback and for letting us know that your issue has been resolved. Others might benefit from having this workaround that you shared in case someone experienced the same problem (though we don't recommend rolling back or downgrading the Firmware). Lastly, I am hopeful that things will be greater especially with ReadyCLOUD once the migration is complete and the 6.5.0 is officially available. Kindly mark this thread resolved by clicking the “Accept as Solution” button.
Kind regards,
BrianL
NETGEAR Community Team
BrianL2
Apr 22, 2016NETGEAR Employee Retired
Hi RyeBread,
Welcome to the community!
Is your PC up to date? Are there any Firewall or AV security software that might be blocking the ReadyCLOUD desktop app?
Kind regards,
BrianL
RyeBread
Apr 27, 2016Tutor
HELLO and thanks
Yes my pc's, readycloud App, and my readyNAS102 are all up to date and all firewalls i turned off to try and still samething, sometimes it works and other times nothing
- BrianL2Apr 27, 2016NETGEAR Employee Retired
Hi RyeBread,
Thanks for the information that you've provided. This seem to work on my end and don't see any problem at the moment. Have you consulted our support team about this?
Kind regards,
BrianL
NETGEAR Community Team- RyeBreadApr 27, 2016Tutor
Thats ok... All I had to do is DOWN grade to the OLD Firmware(6.4.1) on my readynas.. there is something wrong with the 6.4.2 ;) oh well, maybe all will be fixed in the NEW "MyNETGEAR" and windows App and the new Firmware 6.5,,, "soon to be out in May"....
- BrianL2Apr 28, 2016NETGEAR Employee Retired
Hi RyeBread,
Kind regards,
BrianL
