jukkaforss
Sep 12, 2016Tutor
ReadyCLOUD Mac client and MacOS Sierra, share sync not working
Hi, I upgraded my Mac OS version to new MacOS Sierra GM. Share sync stopped working after that. 2016-09-12;18:17:53.0;[13272];[3];D;Scanning - Start scanning path: /Photos Library.photosl...
jukkaforss
Sep 14, 2016Tutor
It is actially working, it just takes long time for one cycle.
Big question is, what it is doing in time of "Server starting serivce for share" messages, which lasts 3 hours 40 minutes ?
Also smaller folder which had only couple of files, that "Server starting serivce for share" phase took many minutes.
Here is the whole cycle, from the log:
Start of the scan cycle.
2016-09-14;12:19:35.9;[13272];[3];D;Scanning - Start scanning working folder: / 2016-09-14;12:19:35.9;[13272];[3];D;Scanning - Start scanning path: / 2016-09-14;12:19:35.9;[13272];[3];W;updateFileCache - Cache path path is not allowed : /Users/jukka/ReadyCLOUD/PhotosLibrary (readynas)/.DS_Store 2016-09-14;12:19:35.9;[13272];[3];W;updateFileCache - Cache path path is not allowed : /Users/jukka/ReadyCLOUD/PhotosLibrary (readynas)/Icon^M 2016-09-14;12:19:36.2;[13272];[3];D;Scanning - Start scanning path: /Photos Library.photoslibrary 2016-09-14;12:19:36.5;[13272];[3];D;Scanning - Path </Photos Library.photoslibrary/Previews> was not found in scanning folder. Mark as deleted it.
And end of the scanning cycle, this takes around 2 hours 8 minutes.
2016-09-14;14:27:12.6;[26649];[3];D;Scanning - Start scanning path: /Photos Library.photoslibrary/resources/media/version/6c/00 2016-09-14;14:27:12.7;[26649];[3];D;Scanning - Start scanning path: /Photos Library.photoslibrary/database/Versions/2008/04/15/20080415-205138/nP%QMLQaRq67hWnXIQ+vTQ 2016-09-14;14:27:12.9;[26649];[3];D;Scanning - Start scanning path: /Photos Library.photoslibrary/resources/proxies/derivatives/ba/00/ba7b 2016-09-14;14:27:13.0;[26649];[3];D;Scanning - Start scanning path: /Photos Library.photoslibrary/resources/proxies/derivatives/af/00/af7b 2016-09-14;14:27:13.6;[26649];[4];I;Server <192.168.1.20:80> Version is <1.2.63> 2016-09-14;14:27:14.9;[26649];[4];W;Server starting serivce for share <PhotosLibrary> ... 2016-09-14;14:27:16.1;[26649];[4];W;Server starting serivce for share <PhotosLibrary> … 2016-09-14;14:27:17.3;[26649];[4];W;Server starting serivce for share <PhotosLibrary> ... 2016-09-14;14:27:18.4;[26649];[4];W;Server starting serivce for share <PhotosLibrary> ...
Now starts these "Server starting serivce for share" messages and those lasts 3 hours 40 minutes.
2016-09-14;18:08:20.7;[26649];[4];W;Server starting serivce for share <PhotosLibrary> ...
2016-09-14;18:08:22.0;[26649];[4];W;Server starting serivce for share <PhotosLibrary> ...
2016-09-14;18:08:23.4;[26649];[4];W;Server starting serivce for share <PhotosLibrary> ...
2016-09-14;18:08:24.8;[26649];[4];W;Server starting serivce for share <PhotosLibrary> ...
2016-09-14;18:11:10.9;[26649];[4];D;Current cursor json: {
"entries" : [
"\/Photos Library.photoslibrary",
"size" : 0,
"is_dir" : true,
"modified" : "1449656564382552",
"client_modified" : "0",
"md5sum" : "0"
],Then it lists changed files and starts the sync phase.
"\/Photos Library.photoslibrary\/Database\/Versions\/2015\/01\/14\/20150114-235545\/ex3%vRRhTBye1g38ZHLSxg\/Version-1.apversion",
"size" : 2341,
"is_dir" : false,
"modified" : "1449712363726601",
"md5sum" : "b774ba7c06a6d1f7ad54ec4380964d01"
"cursor" : "205648A1473863233",
"reset" : "1"
2016-09-14;18:11:11.3;[26649];[3];I;Syncing - Received status from server, remote cursor <205648A1473863233>, local cursor <206031A1473799118>, reset flag <1>
2016-09-14;18:11:11.3;[26649];[3];C;Syncing - Path </Photos Library.photoslibrary/Thumbnails/2008/04/15/20080415-205138/TAmQUGiGSBiMl8WnaNgWYA> already marked deleted and now ignore server's version.
2016-09-14;18:11:11.3;[26649];[3];W;Syncing - Equal file </Photos Library.photoslibrary/Database/Versions/2010/07/19/20100719-154422/eAifvrcIQw6Nw9A1c+tIHg/Version-1.apversion> file already exist in local folder. Just update cache.
2016-09-14;18:11:11.5;[26649];[3];W;Syncing - Equal file </Photos Library.photoslibrary/Database/Versions/2008/04/15/20080415-205138/FcM6h3xdTGy+v9xtyWMpNw/Version-1.apversion> file already exist in local folder. Just update cache.
2016-09-14;18:11:11.7;[26649];[3];C;Syncing - Path </Photos Library.photoslibrary/resources/modelresources/108/81/lQhm3NfjTLOH8oXwpCm88Q> already marked deleted and now ignore server's version.
2016-09-14;18:11:11.7;[26649];[3];W;Syncing - Equal file </Photos Library.photoslibrary/Database/Versions/2008/04/15/20080415-205138/B3Eg0cAARkWWU6ijUfROxA/Version-1.apversion> file already exist in local folder. Just update cache.Sync plase lasts around 3 hours 30 minutes.
2016-09-14;21:40:12.7;[26649];[3];D;Syncing - Schedule delete task for path </Photos Library.photoslibrary/Masters/2015/08/25/20150825-133155/IMGP0029.PEF> 2016-09-14;21:40:12.7;[26649];[8];D;Client: ...372 Start deleting file from server: /Photos Library.photoslibrary/resources/modelresources 2016-09-14;21:40:12.7;[26649];[9];D;Client: ...372 Start deleting file from server: /Photos Library.photoslibrary/Masters/2015/08/25/20150825-133155/IMGP0029.PEF 2016-09-14;21:40:24.1;[26649];[9];D;Client: ...372 Deleted file from server: /Photos Library.photoslibrary/Masters/2015/08/25/20150825-133155/IMGP0029.PEF 2016-09-14;21:41:12.7;[26649];[4];E;Task <delete> failed, reason: <>, system error: <System Error: Unknown error: 107 (107)> 2016-09-14;21:41:12.7;[26649];[7];E;Task <delete> failed, reason: <>, system error: <System Error: Unknown error: 107 (107)> 2016-09-14;21:41:12.7;[26649];[8];E;Task <delete> failed, reason: <>, system error: <System Error: Unknown error: 107 (107)> 2016-09-14;21:41:12.8;[26649];[3];D;Scanning - Start scanning working folder: / 2016-09-14;21:41:12.8;[26649];[3];D;Scanning - Start scanning path: /
Then it starts another cycle.
Some sort of log management would be nice to implement to this prouduct; after one week for example it switch log and compress old one and stores maybe 10 of those compressed logs.
-Jukka-
BrianL2
Sep 15, 2016NETGEAR Employee Retired
Hi jukkaforss,
Thanks for these logs. I am also not sure what does this action /or message do. I will post back once I hear back from my colleagues.
Kind regards,
BrianL
NETGEAR Community Team
