everytime
Jan 30, 2016Guide
Suddenly unable to get to NAS via ReadyCLOUD
For the past week or ten days, I've been unable to connect to my NAS via ReadyCLOUD. Previously I have had no problems. So, I thought I'd reboot the server and do some dust removel while it was of...
JennC
Feb 06, 2016NETGEAR Employee Retired
Hello wlcox,
Are you getting the same problem on other computers? Also, please see if same when you are on same LAN where the NAS is.
The latest FW is 6.4.2, you might want to try updating.
wlcox
Feb 08, 2016Aspirant
Yes, I have tried 2 different computers form 2 different remote locations.
Yes, it works fine when I access from a system on the same LAN as the NAS.
Re: firmware update - When I click on "check for updates" on the "system" page of the admin console, it tells me that I have the latest verson already (6.4.1) Same thing happens from the "system/settings" page. Power-cycled the NAS and it still tells me it is up to date! Are you saying I should ignore what the NAS thinks and force a firmware update?
- StephenBFeb 08, 2016Guru - Experienced User
Netgear releases for manual downloading first, then the update server. 6.4.2 was released last week, and some folks from Netgear said it would be put on the update server today.
So either wait just a bit longer and try again - or do the manual download/install.
- wlcoxFeb 08, 2016Aspirant
Updated manually. Same problem with the ReadyCloud app. Remotely, I can surf to readycloud.netgear.com and login and successfully access the NAS, but not with the app. The app claims that I am signed in and shows the name of the NAS, but the "connecting..." gear just spins and I never gain access to the NAS through the app. This test was carried out on a Win7 box.
- BrianL2Feb 08, 2016NETGEAR Employee Retired
Hi wlcox,
Had the same problem today and I'm already checking it with my colleagues. I will keep you posted.
Kind regards,
BrianL
NETGEAR Community Team
