leahcimd1
Jan 15, 2015Apprentice
ReadyCloud & ReadyNAS duo v2
Hi,
How do I add my two ReadyNAS duo v2's to ReadyCloud?
When I run the ReadyCloud Discovery Page and press the backup button on them they are not discovered.
- NhellieVirtuosoYou will have to use ReadyNAS remote client since the Duo does not support ReadyCloud. Check this thread, it might give you some information about legacy products and remote:
viewtopic.php?f=23&t=79513- kokoschAspirant
Now what can I do?
ReadyNas Remote seems to be not supported by indows 10.ReadyCloude is not supported by my ReadyNas Dou V2.
I need help- EskenderNGNETGEAR Employee Retired
Hello,
There is a ReadyNAS Remote Beta App with WIndows 10 support.
Bye,
Eskender
- leahcimd1ApprenticeThanks,
But, I am currently running version 1.6.5.24 of ReadyNAS Remote on Desktop.
I have ReadyCloud on my laptop.
So it looks like I will reverting to ReadyNAS Remote on my laptop. - RXLuminaryReadyCloud is only supported on ReadyNAS OS 6 models. The ReadyNAS Duo v2 is an OS 5 model.
You may use ReadyNAS Remote in accessing your shares remotely on your ReadyNAS Duo v2. Let me share to you the latest version of ReadyNAS Remote Desktop Client software for Windows and MAC before the ReadyCloud Client came out, here are the links below:
Windows: http://www.readynas.com/contributed/mdg ... 6.5.23.exe
Mac: http://www.readynas.com/contributed/mdg ... 1.2.15.pkg
