Blueray3
Jul 08, 2018Guide
readycloud android app not connecting
In past several days, can no longer login to ReadyCloud account with android mobile app. Colleague on different ReadyCloud account having same problem. I can login from Windows ReadyCloud app, and ...
- Retired_MemberJul 11, 2018
Hi
If you are facing VPN disconnected issue on Android app or Windows client,please turn off and turn on ReadyCLOUD service in admin UI or simply reboot the device to force restart leafp2p service.after that you will be able to get VPN connection again.
tj90
Jul 10, 2018Aspirant
Still no joy for me. I see my NAS on the app and it says it's online, but when I try to enable backup, I'm disconnected.
Skierguy
I have been told their engineers will look into it. I had to shut down the app in settings and restart it for it to log in and to start uploading. It was initially okay, but now seems to drop out a bit and is slow and is now stopping or slowing to a crawl. It does show i am logged in and stalls at "Uploading" now. Was fast this morning. I seem to be able to access my files via the app, but the media backup of pics is now stalled
