Blueray3
Jul 08, 2018Guide
readycloud android app not connecting
In past several days, can no longer login to ReadyCloud account with android mobile app. Colleague on different ReadyCloud account having same problem. I can login from Windows ReadyCloud app, and ...
- Retired_MemberJul 11, 2018
Hi
If you are facing VPN disconnected issue on Android app or Windows client,please turn off and turn on ReadyCLOUD service in admin UI or simply reboot the device to force restart leafp2p service.after that you will be able to get VPN connection again.
Marc_V
Jul 11, 2018NETGEAR Employee Retired
Hi Skierguy
Right, The engineering team is now investigating this issue and working on a resolution.
Hopefully an update can be provided the soonest.
Regards
Frasswass
Jul 24, 2018Aspirant
My app is still forever stuck saying cached and when trying to do a media back up, not only is it thing to backup all the previous pictures that should already be on the drive but it is not progressing at all with the status bar just sitting saying "Uploading... (4730 left) Waiting for connection..."
- SkierguyJul 24, 2018AspirantI would do a forced shutdown of the app in your settings. If that does not work reboot your nas, since you are unable to connect to the service. Cache only means what you have saved on your phone. You need to see 'logging in' or connected. It has been working okay lately but is slow sometimes.
- VarkGripperJul 29, 2018Aspirant
I have the same as all the previous comments. Have re-installed App on Android, rebooted NAS, signed out signed in. App just shwos 'Refreshing' Why is that you get a whole host of people reporting the same issue but still offer the same advice, "Reboot everything" something must be wrong with the App. Checked on iPad and working fine!
