Blueray3
Jul 08, 2018Guide
readycloud android app not connecting
In past several days, can no longer login to ReadyCloud account with android mobile app. Colleague on different ReadyCloud account having same problem. I can login from Windows ReadyCloud app, and ...
- Retired_MemberJul 11, 2018
Hi
If you are facing VPN disconnected issue on Android app or Windows client,please turn off and turn on ReadyCLOUD service in admin UI or simply reboot the device to force restart leafp2p service.after that you will be able to get VPN connection again.
Skierguy
Jul 29, 2018Aspirant
You realize this is a community and I have no affiliation with Netgear right? I only suggest what worked for me and that I have contacted tech support. Perhaps you should contact them yourself. It is working better than it has for me after doing so.
VarkGripper
Apologies, not casting aspertions on users, juts frustrated that Netgear are not the most pro-active supplier.
