Blueray3
Jul 08, 2018Guide
readycloud android app not connecting
In past several days, can no longer login to ReadyCloud account with android mobile app. Colleague on different ReadyCloud account having same problem. I can login from Windows ReadyCloud app, and ...
- Retired_MemberJul 11, 2018
Hi
If you are facing VPN disconnected issue on Android app or Windows client,please turn off and turn on ReadyCLOUD service in admin UI or simply reboot the device to force restart leafp2p service.after that you will be able to get VPN connection again.
Marc_V
Jul 11, 2018NETGEAR Employee Retired
Hi Skierguy
Right, The engineering team is now investigating this issue and working on a resolution.
Hopefully an update can be provided the soonest.
Regards
Skierguy
Jul 31, 2018Aspirant
I am connected but the auto media backup seems to stall this last week. Also my other phone fails to backup photos automatically as well. I have done an app restart. Any suggestions? Was working fine for awhile.
