mikecusumano
Dec 15, 2016Aspirant
ReadyCLOUD Android
Hi, At my wits end with this. Myself and another employee can connect to the ReadyNAS with the ReadyCLOUD app when using our Android phone wifi and on the local netork. We cannot connect if we ar...
- Dec 16, 2016
OK, I resolved this myself.
Apparantly the X next to Services is bad so I went down that route to TS I Found this thread and edited the lnconfiguration.xml with WinSCP and rebooted. All good!
Anyone else looking at this thread, you will need to enable SSH and give your admin account SSH rights under the user account on the dashboard.
You can close this now. Thanks.
Dec 15, 2016Guru - Experienced User
mikecusumano wrote:
My setup has the RN with a static IP and it is setup with ReadyCloud=ON on the NAS dashboard. The dashboard does however have a check mark next to internet and an X next to is saying "services unavailable".
Usually this means that you forgot to configure a DNS server for the NAS. Check the subnet mask and gateway as well.
Solve that first, and then see where you are with ReadyCloud.
- mikecusumanoDec 15, 2016Aspirant
Thanks for the quick reply. The IP setup is as follows:
IP=172.16.1.11
Mask=255.255.255.0
GTWY=172.16.1.1
DNS=8.8.8.8, 208.67.222.222
Thanks
and IPv6 Disabled
- StephenBDec 15, 2016Guru - Experienced User
That looks ok, though of course only you know the correct gateway IP.
Though OpenDNS will block some sites correct? Maybe try a test without it.
No difference. I wish I had an iPhone to try to see if it might just be the Android app. So nothing has to be changed on the ReadyCLOUD settings with ports?
