mikecusumano
Dec 15, 2016Aspirant
ReadyCLOUD Android
Hi, At my wits end with this. Myself and another employee can connect to the ReadyNAS with the ReadyCLOUD app when using our Android phone wifi and on the local netork. We cannot connect if we ar...
- Dec 16, 2016
OK, I resolved this myself.
Apparantly the X next to Services is bad so I went down that route to TS I Found this thread and edited the lnconfiguration.xml with WinSCP and rebooted. All good!
Anyone else looking at this thread, you will need to enable SSH and give your admin account SSH rights under the user account on the dashboard.
You can close this now. Thanks.
mikecusumano
and IPv6 Disabled
Dec 15, 2016Guru - Experienced User
That looks ok, though of course only you know the correct gateway IP.
Though OpenDNS will block some sites correct? Maybe try a test without it.
- mikecusumanoDec 15, 2016Aspirant
No difference. I wish I had an iPhone to try to see if it might just be the Android app. So nothing has to be changed on the ReadyCLOUD settings with ports?
I also wanted to ask about the "X Services Unavailable" on the cloud menu?
- StephenBDec 15, 2016Guru - Experienced User
That was why I suggested checking the network. You should see green checks next to both Internet Available and Services Available.
It's possible that your firewall is blocking port 6300 inbound, so maybe check on that next (see the security tab on ReadyCloud settings).
Using the readycloud portal might also help you sort this (readycloud.netgear.com)
