mikecusumano
Dec 15, 2016Aspirant
ReadyCLOUD Android
Hi, At my wits end with this. Myself and another employee can connect to the ReadyNAS with the ReadyCLOUD app when using our Android phone wifi and on the local netork. We cannot connect if we ar...
- Dec 16, 2016
OK, I resolved this myself.
Apparantly the X next to Services is bad so I went down that route to TS I Found this thread and edited the lnconfiguration.xml with WinSCP and rebooted. All good!
Anyone else looking at this thread, you will need to enable SSH and give your admin account SSH rights under the user account on the dashboard.
You can close this now. Thanks.
Dec 16, 2016Guru - Experienced User
Are you seeing anything at readycloud.netgear.com?
mikecusumano
Dec 16, 2016Aspirant
- JennCDec 16, 2016NETGEAR Employee Retired
Hello mikecusumano,
To close this topic, please mark the appropriate post as accepted solution.
Feel free to post any comments, suggestions and questions. Thank you for your contribution!
