alyin
Feb 01, 2021Aspirant
Readycloud can't find my device readynas rndp400
Readycloud can not find the Readynas Pro 4 on the network, I bought this used readynas pro 4 long time ago, the serial number has been registered to the first owner, could it be the problem? Also si...
- Feb 01, 2021
ReadyCloud only supports NAS running OS-6. It is possible to convert your NAS to OS-6 if you wish. Netgear doesn't support it, but many folks here have done it. The lack of support really doesn't matter in your case, since Netgear doesn't provide support for used NAS either. The process is destructive, so you'd need to have a full backup of the files if you wish to do the conversion.
If you do convert, I'd also recommend upgrading the Pro-4 to 2 GB of RAM - all shipping OS-6 ReadyNAS have at least 2 GB of memory.
Note it is important to verify the model of your NAS before converting it. The Pro and Ultra can be.converted, but the NVX cannot be.
alyin wrote:
Also since I update the firmware to 4.2.31, I can not login the admin page anymore, use the default admin and netgear1 doesn't work.
Simply updating the firmware to 4.2.31 wouldn't change the admin password. You can reset it back to netgear1 by doing an OS reinstall via the front panel. This will also reset your network connection to use DHCP (which is the default setting). See pages 21-22 here for instructions: https://www.downloads.netgear.com/files/GDC/RNDU2000/ReadyNAS_Ultra_UltraPlus_NVX_Pro_HW_en_8July11.pdf
Feb 01, 2021Guru - Experienced User
- alyinFeb 02, 2021Aspirant
Thanks millions!
