Alfred_GS
Dec 03, 2015Aspirant
ReadyCloud Client is nos connecting
Hello, Our Readycloud Client is not able to connect. This morning was working just fine. Web service is working fine. There is some kind of problem with this service? There is someone with t...
JennC
Dec 03, 2015NETGEAR Employee Retired
Hello Alfred_GS,
Can you check if ReadyCloud is turned ON and if Internet and Services are both online? They both should have green check.
You can try turning ReadyCloud off then on.
