Archytas
Feb 02, 2015Aspirant
ReadyCloud Connection Secure?
ReadyCloud advertises "creates a secure, private cloud experience" and "VPN-like access". I chatted with Netgear support and they could not come up with a documented level or protocol of encryption s...
Alfred_GS
Oct 21, 2015Aspirant
Hello,
We have a client that manages medical information needs to be sure that the information is secure before purchasing a NAS that supports ReadyCloud.
Do we have a firm answer in what kind or encryption do we use in this version of ReadyCloud?
Thanks and regards
Oct 21, 2015Guru - Experienced User
Not sure if the encryption on the VPN link actually matters, since we do know that with ReadyCloud enabled you can access the data with normal http (not even https).
I suspect you'll need a different remote access solution.
- Alfred_GSOct 27, 2015Aspirant
Hello,
Thanks for your reply. You are right we need another kind of solution.What a shame.
It would be great if ReadyCloud could let you choose between working on http and https. That would be great.
Thanks for all and regards.
