Nepamoon
Feb 15, 2016Aspirant
ReadyCloud Desktop App not working but web portal is working
I haven't been able to access my NAS via the desktop app however I can access the web portal and see my files with no issue. I've used various version of the desktop app and still have the same issue (v1.7, v1.8, v.1.9) and also disable my friewall. The only solution that seems to temporary fix the issue is to reboot my NAS but I rather not do that all the time.
I am running Windows 10 on a lenovo laptop.
It just keeps saying 'Connecting' and then the app closes.
Any help will be greatly appreciate
Thanks!
Haze
- mdgm-ntgrNETGEAR Employee Retired
Which services and apps are you running?
Which firmware are you running?Welcome to the Community!
- NepamoonAspirant
Thanks for the welcome :)
Firmware: 6.4.2
Apps - AV only
I am currently away and isn't able tolog into the admin page to see what services i have.
- BrianL2NETGEAR Employee Retired
Hi Nepamoon,
Does this happen too on another PC (WIN7 or other)? How about using the mobile app?
Kind regards,
BrianL
NETGEAR Community Team
- matsyouriAspirantAll shares visible on web portal. Problem present on both 6.4.1 and 6.4.2.
- matsyouriAspirantIt is local connection. Both LAN/WLAN are ok.
- matsyouriAspirantSome minutes ago I had connection thru mobile data. Let's see how much it will last.
