jah313
Dec 18, 2015Tutor
ReadyCloud does not connect (Apps or portal)
I have two 516's and they are both on the same network (for now). The firmware is updated and they run fine when I am in the office and connected via hardwire or WiFi. But, when away from the office ...
jah313
Dec 20, 2015Tutor
That sounds like a great solution, but I am not sure how to do that. Is there a thread somewhere else where I can learn about the setup?
Dec 20, 2015Guru - Experienced User
I sketched it out above. There are a couple of similar threads on the forum, for instance here: https://community.netgear.com/t5/Using-your-ReadyNAS/FTP-access-configurations-how-to/td-p/830603
- jah313Dec 21, 2015Tutor
Thank you!!!
