byaremko
Mar 19, 2020Tutor
ReadyCLOUD Error 24002000011
Dear Netgear Support: Would one of you be willing to help me resolve error 24002000011? This is the error message I receive when attempting to enable ReadyCLOUD on my old ReadyNAS Pro 6. Based ...
- Mar 20, 2020
Hi byaremko,
The fix has been applied and the unit has been rebooted. Please check if the issue is fixed and if the fans are working.
JohnCM_S
Mar 20, 2020NETGEAR Employee Retired
Hi byaremko,
Welcome to the Community!
Can you take a picture of the sticker that contains the serial number and the model number of the NAS? This can be found at the rear panel of the chassis. You may send the image to me via private message.
byaremko
Mar 20, 2020Tutor
Thanks all for the responses thus far, I just PM'ed JohnCM_S the link to the picture of the sticker on the NAS (no option to attach anything to PM).
Thanks,
-Bohdan
- JohnCM_SMar 20, 2020NETGEAR Employee Retired
Hi byaremko,
- byaremkoMar 20, 2020Tutor
Problem solved!
A huge heartfelt THANK YOU to JohnCM_S for agreeing to take this on and resolve it so quickly. I have confirmed that the connection to ReadyCLOUD now works. This will most definitely help tide us over with remote access until I can upgrade to a newer NAS later in the year. Thanks also to StephenB for recommending I reach out to JohnCM_S .
I would be remiss if I didn't also take this opportunity to thank mdgm for some help behind the scenes and for the countless posts I have benefited from implicitly over the years; the fact that we still use this ReadyNAS Pro 6 religiously on a daily basis can be directly tied to knowledge picked up from mdgm over the years.
Be safe all!
-Bohdan
