rjwerth
Apr 09, 2017Luminary
Readycloud for Android
I have been unable to get to my servers using Readycloud for Android for 3 days now. I have been able to get in using Windows. I have reset my phone but no luck signing into Readycloud.
BingkeX
Apr 10, 2017NETGEAR Expert
Just want to collect some info to clear the issue.
Which device do you own? Netgear router or Readynas Storage? And what is the firmware version of your devcie?
What is your issued andriod device's android version?
You said you can get using Windows, do you mean you can get access to device via readycloud windows client? What is the connect method by Windows readycloud client? Connected(VPN) or Connected(Local)?
Are the network of your Netgear device and phone in same LAN when you try to connect server by readycloud android app?
- rjwerthApr 12, 2017Luminary
It finally started working again after a full phone reboot.....
- BingkeXApr 12, 2017NETGEAR Expert
Hello rjwerth,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!Regards.
