Vzero00
Dec 15, 2019Guide
ReadyCloud Mobile App Android v2.04 no background setting still
Currently using Android App ReadyCLOUD on a Samsung Note 9. Also have an iPhone XR using the same APP. On iOS environment, the APP has the "Backup in Background" setting. However in the Android env...
Marc_V
Dec 18, 2019NETGEAR Employee Retired
Welcome to the Community!
Run in background feature was not added on the Android App version, Hopefully this will be included on future software update.
The App should continue to sync even if it is not pulled up on the screen.
HTH
Regards
- Vzero00Dec 23, 2019Guide
Do you happen to know if this is feature had been submitted to the developers for "furture software update"?
Or
Do you happen to know if there is a ETA on when this feature would be available as it is already available on the iOS platform?
Thanks
