drhjorgensen
Nov 17, 2020Aspirant
ReadyCLOUD NAS online (VPN Disconnected)
I am getting the dreaded ReadyNAS "Online (VPN Disconnected)" message for a single ReadyNAS. We have two identical ReadyNAS RN31200's in two different locations, each running the latest firmware. Thi...
drhjorgensen
I have downloaded the logs and here's what I see in leafp2p.log after a reboot of the NAS:
-- Reboot --
Nov 17 10:53:06 XXXNAS leafp2p[2633]: Starting leafp2p
Nov 17 10:53:06 XXXNAS leafp2p[2633]: Parsing config
Nov 17 10:53:06 XXXNAS leafp2p[2633]: Access rules valid 1
Nov 17 10:53:06 XXXNAS leafp2p[2633]: Service valid remote 1
Nov 17 10:53:06 XXXNAS leafp2p[2633]: service remote ReadyNAS Remote 0 1 0
Nov 17 10:53:06 XXXNAS leafp2p[2633]: Service valid replication 1
Nov 17 10:53:06 XXXNAS leafp2p[2633]: service replication ReadyNAS Replication 1 0 0
Nov 17 10:53:06 XXXNAS leafp2p[2633]: Service config valid 1
Nov 17 10:53:06 XXXNAS leafp2p[2633]: P2P Created by Pramod Immaneni and Jeff Capone
Nov 17 10:53:06 XXXNAS leafp2p[2633]: P2P Designed and Developed by Pramod Immaneni
Nov 17 10:53:06 XXXNAS leafp2p[2633]: Started...
Nov 17 10:53:06 XXXNAS leafp2p[2633]: Accepting
Nov 17 10:53:47 XXXNAS leafp2p[2633]: SOAP 1.1 fault: SOAP-ENV:Client [no subcode]
Nov 17 10:53:47 XXXNAS leafp2p[2633]: "Name or service not known"
Nov 17 10:53:47 XXXNAS leafp2p[2633]: Detail: getaddrinfo failed in tcp_connect()
Nov 17 10:58:41 XXXNAS leafp2p[2633]: SOAP 1.1 fault: SOAP-ENV:Client [no subcode]
Nov 17 10:58:41 XXXNAS leafp2p[2633]: "Connection timed out"
Nov 17 10:58:41 XXXNAS leafp2p[2633]: Detail: connect failed in tcp_connect()
Nov 17 11:03:01 XXXNAS leafp2p[2633]: SOAP 1.1 fault: SOAP-ENV:Client [no subcode]
Nov 17 11:03:01 XXXNAS leafp2p[2633]: "Connection timed out"
Nov 17 11:03:01 XXXNAS leafp2p[2633]: Detail: connect failed in tcp_connect()
Nov 17 11:07:20 XXXNAS leafp2p[2633]: SOAP 1.1 fault: SOAP-ENV:Client [no subcode]
Nov 17 11:07:20 XXXNAS leafp2p[2633]: "Connection timed out"
Nov 17 11:07:20 XXXNAS leafp2p[2633]: Detail: connect failed in tcp_connect()
Nov 17 11:11:40 XXXNAS leafp2p[2633]: SOAP 1.1 fault: SOAP-ENV:Client [no subcode]
Nov 17 11:11:40 XXXNAS leafp2p[2633]: "Connection timed out"
Nov 17 11:11:40 XXXNAS leafp2p[2633]: Detail: connect failed in tcp_connect()
Nov 17 11:15:59 XXXNAS leafp2p[2633]: SOAP 1.1 fault: SOAP-ENV:Client [no subcode]
Nov 17 11:15:59 XXXNAS leafp2p[2633]: "Connection timed out"
Nov 17 11:15:59 XXXNAS leafp2p[2633]: Detail: connect failed in tcp_connect()
Nov 17 11:20:19 XXXNAS leafp2p[2633]: SOAP 1.1 fault: SOAP-ENV:Client [no subcode]
Nov 17 11:20:19 XXXNAS leafp2p[2633]: "Connection timed out"
Nov 17 11:20:19 XXXNAS leafp2p[2633]: Detail: connect failed in tcp_connect()
And the readycloud.log shows:
-- Reboot --
Nov 17 10:55:19 XXXNAS rcbrokerd[3474]: ERROR:handler.cpp:307: ERROR [syscmd:AddNetwork]: AddNetwork failed
Nov 17 10:55:19 XXXNAS rcbrokerd[3474]: ERROR:handler.cpp:1351: ERROR [syscmd:AddRemoteUserHandler] :AddRemoteUser XXX_sr failed with code=-1
Nov 17 10:55:19 XXXNAS rcbrokerd[3475]: ERROR:handler.cpp:307: ERROR [syscmd:AddNetwork]: AddNetwork failed
Nov 17 10:55:19 XXXNAS rcbrokerd[3475]: ERROR:handler.cpp:1351: ERROR [syscmd:AddRemoteUserHandler] :AddRemoteUser ZFNP-336-564pinfoXXX failed with code=-1
Marc_V
Nov 18, 2020NETGEAR Employee Retired
Have you tried rebooting the NAS and also checking your NIC settings if you have any DNS Server addresses added?
You may also want to try toggling the ReadyCloud service from the Cloud tab
HTH
