uffgnu14
Nov 25, 2015Luminary
ReadyCLOUD not connecting
ReadyNAS Ultra2 Plus RN OS 6.4.1-RC3 ReadyCLOUD 1.8.1220.372 for Windows Windows 10 Home Hi Can not connect with ReadyCLOUD Windows client over cellular network. Tested with phone connect...
- Nov 27, 2015HiI did some tests with a fresh install of ReadyCLOUD on my laptop with Windows 10.
This time I managed to get connected over cellular network. Maybe I waited a bit longer and finally
got "Connected(VPN)". Time to connect is guite long, varies between 1-2 minutes and sometimes never within 3 minutes.Regards,
Ulf
uffgnu14
Nov 26, 2015Luminary
Hi
Yes, I would like to do that also but I don't have the ability in the near future.
Ulf
Ulf
- JennCNov 27, 2015NETGEAR Employee Retired
Hello uffgnu14,
You may need to check on that because cellular networks may also have restrictions/firewall that may block some activities.
You can also try adding a friend who can possibly connect to a normal network setup to access one of the shares via ReadyCloud.
