uffgnu14
Nov 25, 2015Luminary
ReadyCLOUD not connecting
ReadyNAS Ultra2 Plus RN OS 6.4.1-RC3 ReadyCLOUD 1.8.1220.372 for Windows Windows 10 Home Hi Can not connect with ReadyCLOUD Windows client over cellular network. Tested with phone connect...
- Nov 27, 2015HiI did some tests with a fresh install of ReadyCLOUD on my laptop with Windows 10.
This time I managed to get connected over cellular network. Maybe I waited a bit longer and finally
got "Connected(VPN)". Time to connect is guite long, varies between 1-2 minutes and sometimes never within 3 minutes.Regards,
Ulf
uffgnu14
Nov 26, 2015Luminary
Hi
Yes, I would like to do that also but I don't have the ability in the near future.
Ulf
Ulf
JennC
Nov 27, 2015NETGEAR Employee Retired
Hello uffgnu14,
You may need to check on that because cellular networks may also have restrictions/firewall that may block some activities.
You can also try adding a friend who can possibly connect to a normal network setup to access one of the shares via ReadyCloud.
