uffgnu14
Nov 25, 2015Luminary
ReadyCLOUD not connecting
ReadyNAS Ultra2 Plus RN OS 6.4.1-RC3 ReadyCLOUD 1.8.1220.372 for Windows Windows 10 Home Hi Can not connect with ReadyCLOUD Windows client over cellular network. Tested with phone connect...
- Nov 27, 2015HiI did some tests with a fresh install of ReadyCLOUD on my laptop with Windows 10.
This time I managed to get connected over cellular network. Maybe I waited a bit longer and finally
got "Connected(VPN)". Time to connect is guite long, varies between 1-2 minutes and sometimes never within 3 minutes.Regards,
Ulf
uffgnu14
Nov 27, 2015Luminary
Hi
Just wiped the dust of my old laptop with Windows 7 and connected it to my cellular network over phones USB-share.
All worked fine, "Connected(VPN)", files could be accessed as the "admin" account.
Some incompatibilities between Windows 10 and ReadyCLOUD?
Ulf
Ulf
JennC
Nov 27, 2015NETGEAR Employee Retired
Hello uffgnu14,
Probably something else's blocking it. Have you tried uninstalling the desktop client then reboot then reinstall?
