Mixer9999
Dec 03, 2016Tutor
ReadyCLOUD not connecting
I upgraded my Mac Book Pro and IMAC (both on Sierra 10.12.1) to ReadyCloud 1.4 and now it will not connect. When I use the Readycloud app, it shows "Disconnected" when I try to access the admin p...
FramerV
Dec 05, 2016NETGEAR Employee Retired
Hi Mixer9999,
Unfortunately I do not have the link anymore, but I did remember another forum poster having similar issues. His workaround was to downgrade the ReadyCloud App. Would be best to check my.netgear.com and have your device be registered for its warranty and support.
Mixer9999
Dec 05, 2016Tutor
Thanks for the response. My RN212 is registered with Netgear. Is there anywhere to find the previous release of Readycloud so I can downgrade and get back up working?
