Mixer9999
Dec 03, 2016Tutor
ReadyCLOUD not connecting
I upgraded my Mac Book Pro and IMAC (both on Sierra 10.12.1) to ReadyCloud 1.4 and now it will not connect. When I use the Readycloud app, it shows "Disconnected" when I try to access the admin p...
Mixer9999
Dec 05, 2016Tutor
Thanks for the response. My RN212 is registered with Netgear. Is there anywhere to find the previous release of Readycloud so I can downgrade and get back up working?
FramerV
Dec 06, 2016NETGEAR Employee Retired
Hi Mixer9999,
Unfortunately I do not have a copy of it. Would be best if you get in touch with support.
