webZplus
Dec 27, 2016Star
ReadyCloud not connecting
Re: ReadyNAS 202 / Firmware 6.6.0 / ReadyCloud Client v1.15 So it's nearly a year that I have been trying to connect my NAS202 via the ReadyCloud client (v1.15), and I still can't connect using m...
webZplus
Jan 16, 2017Star
Hello FramerV
On the Cloud Tab, both the Internet Available and Services Available have ticks, also the ReadyCloud 'switch' is on, the Proxy and Security settings are blank with the exception of a tick in the 'Encryption' box.
It would be great to resolve this issue as it has gone on far too long.
Cheers
FramerV
Jan 17, 2017NETGEAR Employee Retired
Hi webZplus,
Are you already using the latest firmware for the ReadyNAS?
ReadyNAS OS 6 Software Version 6.6.1
- BrandonKApr 12, 2017Aspirant
Hi FramerV,
I am having the same problem. We have both green checks under the cloud tab, we are using the 6.6.1 firmware and 1.5.9 app. Everything is working fine with the desktop access. When using the iPad app i can see the server and sometimes i can even go through folders and get to files but more often than not i get "ERROR The operation couldn't be completed at this moment, try again"
Is there anything I'm missing or a setting i need to adjust? It gives the error to the point the app is functionally unusable. Any help or workarounds would be greatly appreciated!
Thanks,
Brandon
