PeppoVI
May 02, 2017Aspirant
ReadyCLOUD not connecting
- Model ReadyNAS 102 - Firmware 6.7.1 - Internet Available - Services Available When ReadyCloud is ON this message appears: something is preventing the ReadyNas from conneting to the ReadyCLO...
JennC
May 02, 2017NETGEAR Employee Retired
Hello PeppoVI,
The issue on March 30 that was mentioned at Having ReadyCLOUD problems since 3/30/17? discussion was about ReadyCloud turned OFF and it reset the invited ReadyCloud users, if you believe you have lost important data after getting this problem, please check again the discussion because for now, that is more important than enabling ReadyCloud.
Can you post a screenshot, please? Also, did you try another web browser?
PeppoVI
May 03, 2017Aspirant
I did not lose data, I just want to activate readycloud
I tried with other browsers, same problem
- PeppoVIMay 03, 2017Aspirant
In ReadyCLOUD I see the NAS (black mode) but I can't remove it, can you reset my ReadyCLOUD (My Netgear) accounts?
I have 2 accounts:
giuseppezancan@gmail.com
giuseppe@studiozancan.com
