natepiet
Apr 28, 2014Aspirant
ReadyCLOUD Shares Displaying Red Lock
Hi Guys,
I started setting up the ReadyCLOUD for my ReadyNAS (6.1.7) a few weeks back and I'm having some issues.
I can successfully log into https://readycloud.netgear.com and see the 3 tabs across the top (being: Discover, Manage and Access). Then I go to the Access tab to view the shares on my ReadyNAS and they are all displaying a Red Lock Symbol and will not let me access any of the shares. All of the Share's Permissions are set to Everyone - Ready/Write. There is only one ReadyCLOUD account that has been setup on this ReadyNAS and that is my own.
What am I missing...? Thanks in advance.
Example:
- FaustoAspiranttry right button on the red lock ...
- JefferySAspirantHi, I'm normally not one to bring up an old issue but I'm having this exact problem. All of my folders are locked.
Let's take the Music folder, I've reset the file permissions back to default as well as the owner and group to guest. Anonymous access is enabled. On ReadyCloud the permissions are set to everyone R/W.
I don't know what else to do but the red lock is still there. There on all the folders I've created but I'm using the Music folder as an example because it had the lowest possible setting for access you can get.
Anyone have any Ideas why I'm getting red locks on everything especially the Music folder which has full permissions for everyone and guest and anonymous access?
Thanks,
Jeffery - mdgm-ntgrNETGEAR Employee RetiredI would suggest you open a support case.
- JefferySAspirantNot the answer I was hoping for but thanks, I submitted a support case.
- natepietAspirantI couldn't figure it out in the end and decided to ditch the ReadyCLOUD idea and implement FTPS is stead. That is working well for me.
- davesummLuminaryI have the same issue. Can anyone shed any light?
- ReadySECUREApprenticeDid you give the ReadyCLOUD user you added access to the share folder?
- davesummLuminarySure did. I unchecked 'everyone' and checked 'read only' for all users except myself, which i checked as 'read/write'
- mdgm-ntgrNETGEAR Employee RetiredDid you login using the same case for the username as you used when you registered? If not, can you try that? e.g.if when you registered you spelt the user as e.g. "mYNaMe" (no quotes) try spelling it the same way when logging in to ReadyCloud.
- human102GuideThis happened to me yesterday when I changed file permissions via windows and not on the NAS OS. I suppose the attributes/ and permissions are not stored the same. I will just set them through readynas admin now. I did enough testing to "think I know" what I did wrong.. Hope so anyway.
any comments??
