BBuzz's avatar
BBuzz
Apprentice
Nov 12, 2017
readycloud uploading failures
I started uploading files on readycloud early this morning and was sucessful. about 2 hours later I tried again and got failures It is stating in the failure that their was a connection error. Is the system down? Are their problems on the netgear cloud? I have tried different browsers Silverlight and reloaded Chrome with no success. This seemed to have started around 9:30am EST and am still not able to upload at 1:00pm EST Today is 11/12/17
  • It seems that I had to go back in and delete the folders that I had created that I was trying to upload into for some reason during the creation of the folders they failed even though they were showing. So I went back in and deleted the folders recreated them and my uploads went through. So I would say that that was the solution to my problem
  • BingkeX's avatar
    BingkeX
    NETGEAR Expert
    Hi BBuzz,
    Do you try to upload file to nas or router via readycloud?
    If upload file to a nas, what is your nas firmware?
    And what is the file size of your uploaded fail files? Do you set quota for your shares?
    Best Regards.
    • BBuzz's avatar
      BBuzz
      Apprentice
ProSupport for Business
