Synergie
Dec 14, 2015Aspirant
ReadyCloud won't turn on.
Hi I have a ReadyNas pro 6 (RNDP6310) upgraded to OS6 (FW 6.4.1).OS6 works completely fine except 1 thing if i try to enable ReadyCloud it promts me to the message "The ReadyDrop-service isn't sup...
- Dec 16, 2015
The serial number has been programmed into your unit now.
Please check if ReadyCLOUD will turn on.
Synergie
After further investigation and looking around the forum for people with the same issue i maybe found the problem. As discussed here
He got the same issue and got a mismatch in serial numbers. After looking at my device and my configuration i noticed that the OS and the device have different serialnumbers asswell.
Is this the only issue or are there more problems at play ?
Thanks,
Pieter-Jan
