Synergie
Dec 14, 2015Aspirant
ReadyCloud won't turn on.
Hi I have a ReadyNas pro 6 (RNDP6310) upgraded to OS6 (FW 6.4.1).OS6 works completely fine except 1 thing if i try to enable ReadyCloud it promts me to the message "The ReadyDrop-service isn't sup...
- Dec 16, 2015
The serial number has been programmed into your unit now.
Please check if ReadyCLOUD will turn on.
Synergie
After further investigation and looking around the forum for people with the same issue i maybe found the problem. As discussed here
He got the same issue and got a mismatch in serial numbers. After looking at my device and my configuration i noticed that the OS and the device have different serialnumbers asswell.
Is this the only issue or are there more problems at play ?
Thanks,
Pieter-Jan
BrianL2
Dec 14, 2015NETGEAR Employee Retired
Hi Synergie,
You're right that this problem is similar to the link that you mentioned. Kindly pm Skywalker about this problem and hopefully it will be resolved soon.
Kind regards,
BrianL
NETGEAR Community Team
- mdgm-ntgrDec 15, 2015NETGEAR Employee Retired
I have sent you a PM. I can fix the serial number on the unit to match what is on the label.
- mdgm-ntgrDec 16, 2015NETGEAR Employee Retired
- Max_MaasJan 10, 2016Tutor
Hello,
ReadyNAS 102
I've got the exact same issue when I updated at the ver. 6.4.1:
- ReadyCloud won't turn on
- The Serial #'s (webpage / label) are different.
before the update ReadyCloud was working fine, I could reach my NAS from everywherre by mobile app or any pc.
Thanks in advance.
Massimo
