Synergie
Dec 14, 2015Aspirant
ReadyCloud won't turn on.
Hi I have a ReadyNas pro 6 (RNDP6310) upgraded to OS6 (FW 6.4.1).OS6 works completely fine except 1 thing if i try to enable ReadyCloud it promts me to the message "The ReadyDrop-service isn't sup...
- Dec 16, 2015
The serial number has been programmed into your unit now.
Please check if ReadyCLOUD will turn on.
mdgm-ntgr
Dec 15, 2015NETGEAR Employee Retired
I have sent you a PM. I can fix the serial number on the unit to match what is on the label.
mdgm-ntgr
Dec 16, 2015NETGEAR Employee Retired
- Max_MaasJan 10, 2016Tutor
Hello,
ReadyNAS 102
I've got the exact same issue when I updated at the ver. 6.4.1:
- ReadyCloud won't turn on
- The Serial #'s (webpage / label) are different.
before the update ReadyCloud was working fine, I could reach my NAS from everywherre by mobile app or any pc.
Thanks in advance.
Massimo
- mdgm-ntgrJan 10, 2016NETGEAR Employee Retired
Please update to ReadyNASOS 6.4.2-T72 (Beta 2)
I have sent you a PM with further information I require.
