birty1
Jun 24, 2024Aspirant
readynas 102 raid crash
readynas102 it was raided, one drive failed. A new drive was inserted but nothing was recovered and the working drive was not accessible, I made the recovery USB (many times) eventually it turned off...
Jun 24, 2024Guru - Experienced User
birty1 wrote:
I have reclaime installed but as the dock is not recognising the drive it cannot be used ..any help?
While windows won't mount the drive, reclaime should be able to see it. You should also be able to see it in the Windows disk manager.
If that isn't working, then you either have a failed dock or a second failed drive.
You should have had access to the files even when the drive that failed was pulled out. Are you saying that was not the case?
Also, were you running X-RAID or RAID-1? Or were you running RAID-0 with FlexRAID???
birty1 wrote:
On reboot I can see both drives, the new drive is accessible, the second with the date on is seen but not accessible, i can see the volume of data but cannot open the drive.
Can you download the log file zip from the logs page?
Also post a screenshot of what you are seeing on the volume page.
birty1
reclame sees it but no actions available, not available in windows
