birty1
Jun 24, 2024Aspirant
readynas 102 raid crash
readynas102 it was raided, one drive failed. A new drive was inserted but nothing was recovered and the working drive was not accessible, I made the recovery USB (many times) eventually it turned off...
birty1
for some reason it wont let me upload the zip files
Mike
Jun 25, 2024Guru - Experienced User
Don't post them publicly.
If you like, you can put the entire zip into cloud storage (Dropbox, Google Drive, etc). Then send me a private message (PM) using the envelope icon in the upper right of the forum page. Include a link to the log zip - making sure the link permissions are set so anyone with the link can download.
birty1 wrote:
the original set-up was x-raid, i did attempt to change it to flex,
If you did that after the drive failure, then that was a mistake.
