NickyWilkes
May 01, 2017Aspirant
ReadyNas 104 Discoverable but won't link with ReadyCloud
Hi, I apologise if this question is a repeat, tried looking but not found anything... I have a ReadyNAS 104, with 6.6.1 OS on a Virgin V3 Router. I seem to have been affected with the auto accoun...
- May 01, 2017
Hello NickyWilkes,
I deeply apologize for the inconvenience this has caused you. Other users have problems with the data that got deleted due to the ReadyCloud users reset of their ReadyNAS but were not getting that same problem. Have you checked if you are able to get your NAS when you log in at the ReadyCloud portal while you get this problem on ReadyCloud mobile app?
You might want to update the firmware. Firmware 6.7.1 is now available. It may be not available on the update server so you may need to upgrade the firmware manually. You may download the firmware from this link.
Welcome to the community!
JennC
May 01, 2017NETGEAR Employee Retired
Hello NickyWilkes,
biotechguy
May 09, 2017Aspirant
Hi Jen, I had to reboot my NAS into the OSBoot mode. This at least got me back to accessing the Admin account on the NAS. I then updated the firmware. Now all is up to date but I still can't access via ReadyCloud.
