DDickens
Sep 03, 2016Aspirant
ReadyNAS 104 not accessible from Readycloud since account upgrade
Hi, I upgraded my Readycloud account as requested and since that time I have been unable to access the Nas drive remotely. Each time I login the screen starts to load the network drive mappings ...
- Sep 03, 2016
Hello DDickens,
If the issue is already resolved, we encourage you to mark the appropriate post as the accepted solution so this can be of help to other members of the community who are getting the same issue.
Welcome to the community!
mdgm-ntgr
Sep 03, 2016NETGEAR Employee Retired
Which firmware are you running?
When you set a static I.P. did you remember to specify the DNS Server addresses?
Can you send me your logs (see the Sending Logs link in my sig)?
DDickens
is is running 6.5.1 and yes we adjusted the DNS also as per the instructions. We are actaully trying a factory reset and that seems to solve it
- JennCSep 03, 2016NETGEAR Employee Retired
Hello DDickens,
- biotechguySep 04, 2016Aspirant
ReadyNAS 104 not accessible from Readycloud since account upgrade. The ReadyNAS always reports as being "off-line" in the readycloud app. I can access the device from the LAN but not WAN (i.e. the cloud). I haven't been able to find a solution in the on-line communities.
It looks like a common issue but I haven't found a clear solution or a protocol to correct this issue. I have had this ReadyNAS device for 2 years now and haven't been able to use it for it's intended purpose at all.
Thanks,
biotechguy
- StephenBSep 04, 2016Guru - Experienced User
Is ReadyCloud the only problem? If not, then perhaps post one of them, giving the model+firmware with some info on what is going wrong.
