Jeu
Dec 24, 2014Aspirant
Readynas 312 - no shares present in Readycloud
Hi,
After some problems I finally managed to connect my Readynas 312 to Readycloud but all my shares are invisible. In ready cloud the Homepage with Modelnumber and Serialnumber is open and the "Manage" and "Discover" sections are also accessible. In the NAS userinterface on my iMac I created a ReadyCloud user (the user account I use to login to readycloud) but in the cloud there's no user present. I als don't succeed in inviting a user to Readycloud. What could cause these problems and/or how can I fix this?
Thanks
Thanks
- NhellieVirtuosoopen port 6300 and point it to the IP of your NAS.
- JeuAspirantI took your advice (thanks for that by the way) and I can connect to my NAS at "http://readycloud.netgear.com/client/index.html#page=access" but my shares are still not visible.
The connection was made however from my own residence and not from a location outside. As far as I know this should not be a problem because the connection is made by connecting via the servers of ReadyCloud. Also there are nu users present at ReadyCloud and I can't invite users. - JeuAspirantConnection to the NAS shares in ReadyCloud is finally established. I presume the port forwarding needed some time to activate. Thanks for the help Nhellie.
- NhellieVirtuosoNice :)
- soosie999AspirantHI Nhellie
I ahve the same problem - where do I "open port 6300... "
Cheers Soosie - StephenBGuru - Experienced User
He means forward WAN port 6300 to the NAS's local IP address, which is done in your router.soosie999 wrote: HI Nhellie
Cheers Soosie - soosie999AspirantThanks for that.
I have now done that but the port is still not open (according to a checker site) and ReadyCloud still can't see my shares - after 3 days I'm about to give up.
Thanks anyway. - StephenBGuru - Experienced UserDid you try rebooting your router? Also perhaps contact your ISP.
- pdelgesGuideAfter spending some time trying to get ReadyCloud working from my Mac and iPads, I discovered that the SMB service has to be running on the NAS, and selected as an available protocol for the shares you want to access.
In a Mac only environment like here, there was no reason to turn on SMB. Why can't the NAS display a warning when setting up ReadyCloud in such a case? - NhellieVirtuoso
pdelges wrote: After spending some time trying to get ReadyCloud working from my Mac and iPads, I discovered that the SMB service has to be running on the NAS, and selected as an available protocol for the shares you want to access.
Probably because readycloud is more focused on the remote access side (?), this is a good feature though. Try posting it on the "Feature Request" board.
