DJ402's avatar
DJ402
Initiate
Mar 01, 2025
Readynas 314 drives showing red on admin page and volumes gone
My Readynas 314 became unresponsive after a failed drive replacement attempt.  The drive I had on standby didn't work, so I decided to upgrade and transfer the data to a new NAS system.  While waiting for the new equipment, the volumes disappeared from the admin page.  I can boot the system and log into the admin page. I sure hope there is a way to recover this data.  Running firmware 6.10.10.
  • StephenB's avatar
    Download the full zip file from the logs page - there will be more info there on what exactly happened.
    If you want me to take a look, then put the zip into cloud storage (dropbox, etc), and send me a PM (private message) with a link.  Make sure that the permissions are set so anyone with the link can down load.
    You send a PM using the envelope icon in the upper right of the forum page.
    • DJ402's avatar
      DJ402
      Initiate
      So I downloaded USF Explorer ran the trail, it showed recovered data, so I bought the program ($140).  I recovered all my files, worked great!  Highly recommend.
      • StephenB's avatar
        Thanks for following up!
ProSupport for Business
