tiborszabo
May 25, 2020Star
ReadyNAS 316 and others - ReadyCLOUD Web interface only showing Home Folders
Hi all, I have about 7 x ReadyNAS devices running at various sites. This morning (25 May 2020), it seems that anyone accessing their ReadyNAS via ReadyCloud on the web (https://readycloud.netgea...
- May 27, 2020
Yes it is an issue detected by the team and they are working on it. As a workaround you can use the desktop or mobile app to access shares they should not be affected by the issue.
UPDATE: Issue is now resolved. You should be able to see your shares when logged in to the portal.
Regards
tiborszabo
May 27, 2020Star
I've just received word from our agents here in South Africa that this is indeed an issue that Netgear are currently working on.
We wait in hope...
Thanks all for your feedback and input.
Marc_V
May 27, 2020NETGEAR Employee Retired
Regards
